Stupid SES Code Question
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Hi guys. I just bought an 86 Sport Coupe for a whopping $500 and the check engine light is on (the car runs and drives fine, 2.8v6 BTW). I understand the paper clip thing. But, how do you read the codes, I know the flash/pause sequence is given for code 12 but I can't find anything for the other codes and there's no info in my haynes manual about it. So how do ya read em!
Alex
Alex
Re: Stupid SES Code Question
Huh? My haynes manual isn't numbered that way. The only info given is on page 6-3 (no normal numbers) I believe. But it only gives code definitions, not the actual code sequence.
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Haynes 82-92?
Chiltons is different as is Helms.
I have all 3.
What codes are you getting? I'll send you the info on them.
I have all 3.
Ok, I finally got my car back from the tranny shop and now I can pull the code. The only code I'm getting is: flash, flash, flash, pause, flash, flash, flash, flash. So three flashes, a pause, and four flashes. Can anyone please tell me what trouble code this is? I'm assuming it has something to do with fuel/air cause the car is idling horribly.
Alex
Alex
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
https://www.thirdgen.org/service-eng...ht-error-codes
How to read codes and the codes themselves are there.
Yours is flashing 34 - 3 flashes, pause, 4 flashes = 34
Sweet, thanks for the quick reply. Found out one of the wires to MAF was broken. Thanks Again
Alex
Alex
eightsixseven
Dec 16, 2024 01:50 PM
