TBI will only start if I pinch the return line?
Old Jul 20, 2009 | 07:38 PM
kurtis's Avatar
I put a TBI 350 from a 93 surburban in a Land Cruiser and installed it with a walbro gsl395 pump rated somehwhere between 30 and 40psi and the fuel fuel injectors are barely getting fuel? If I pinch the return line pressure builds immediatly and the engien will start. Any suggestions ? this is driving me crazy trying to figure this out. The store I bought the pump from said that i do not need an additional regulator , that the tbi regulator should be fine with this pump. Why will it only run if the return line is pinched?
Old Jul 20, 2009 | 08:45 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: TBI will only start if I pinch the return line?
TBI only needs 12-14 psi.
What kind of fuel pressure are you getting when cranking over the engine? Don't guess. Put a gauge on it somewhere.
Old Jul 20, 2009 | 09:12 PM
kurtis's Avatar
Do have a good gauge you could recomend? As far as I know with the tbi the only way is to put it in line right?
Old Jul 20, 2009 | 09:29 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
Most likely the diaphram on your fuel pressure regulator has failed. You can get the diaphram separately, but an entire TBI rebuild kit is only $25-35 and fairly easy to install.
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
wayshegoes
Aug 17, 2015 12:00 PM
armybyrd
Aug 10, 2015 09:23 PM
Kaweh
Aug 9, 2015 02:54 PM
