needed opinions... what to do.
Old Jul 24, 2009 | 08:17 AM
beatereater's Avatar
Car: 84 Trans am
Engine: 355
Transmission: TH400
Axle/Gears: 343 rear end
Ok... i have a 355 that has been sitting for five maybe six years with no miles on the engine at all, and it wont turn over by hand... what is the best thing to do? (in your opinion)
Old Jul 24, 2009 | 10:01 AM
snardos's Avatar
Car: 1992 camaro z28
Axle/Gears: 2.73:1
Re: needed opinions... what to do.
I would pull the engine apart and relube all of the crank and cam bearing before trying to start it. I helped install a 355 in a friends car that had been sitting for four years and had never been run. We primed the oil system before starting the engine and it fired up great. After running it a while to break in the cam we started to hear some strange noises coming from inside and the oil pressure was dropping. We found out that the cam bearings were ruined and we had to replace the cam, lifters and bearings which meant pulling the engine back out and sending back to the machine shop. IIRC the shop said the assembly lube dried up after all that time. I'm not sure if that's true or if they were just trying to cover themselves, but either way the warranty was long gone after four years.
Old Jul 24, 2009 | 02:11 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
If it has never been run i'd be leery if it was assembled right? Are you sure?
I'd dump out whatever oil/sludge is in it. Refill with new oil.
I'd remove the distributor, and put in an oil pump priming tool, and spin that thing over. Get some oil through the engine.
Then i'd pull all the spark plugs, and squirt light oil into all the cylinders and let it sit for a few mins. Then finally, using a prybar on the flywheel, or a crank turning tool (NOT THE BALANCER BOLT!) rotate the engine over. Once you break it free, then put your plugs back in, and see if it'll fire up. Be ready with starter fluid, your fuel system is probably junk now too.
Old Jul 26, 2009 | 01:23 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
hahaha, they think the engine is still in the car. might want to check out those cam bearings.
Old Jul 26, 2009 | 04:32 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Well ya know for starters when you cay by hand a SCB will be pretty tough to turn over especially if its got spark plugs installed. If you mean by hand and useing a long 2 foot ratchet on the crank or something and it wont turn thats a different story. Otherwise i highly doubt you'll be able to turn it over purely by hand as it takes quite a bit of muscle.
Old Jul 29, 2009 | 04:57 PM
Car: 84 Trans am
Engine: 355
Transmission: TH400
thats what i wanted to hear... i have this one guy that says to pull out the pistons and replace the rings.. didnt want to. ill be writing more later this week.
Old Jul 29, 2009 | 09:10 PM
Car: 84 Trans am
Engine: 355
Transmission: TH400
Trust me... if it hasnt turned over by now i need to do something... so i put some tranny fluid (light oil) down the sparkplug holes and am gonna wait till tomorrow to try again... Also. do you think i should try to turn it over using the starter or just by hand?
Old Jul 29, 2009 | 09:47 PM
by hand, the initial load of the locked up engine on the starter can't be good on it.
Old Jul 30, 2009 | 07:41 AM
Car: 84 Trans am
Engine: 355
Transmission: TH400
I GOT IT!!!!!!!!!!!! YEAAAAAAAAA.... i talked to my uncle last night, he is a chevy sb genius.. he said if the tranny is off then use the bumps on the block that guide the tranny on.. you put a 4 way on that and get a crobar or tire-iron.. even a big screwdriver would work. then you use the crobar as a lever on the flywheel.. it workd and now ive turned it twice over... 740 degrees
Old Jul 30, 2009 | 07:42 AM
Car: 84 Trans am
Engine: 355
Transmission: TH400
thanks for all the imputs and suggestions. i wanted to hear as many options as possible...
Old Jul 30, 2009 | 09:33 AM
now we can start thinking about dropping it in
Old Jul 30, 2009 | 12:14 PM
Car: 84 Trans am
Engine: 355
Transmission: TH400
yep... im sooooo excited... lol
Old Aug 2, 2009 | 02:41 PM
Car: 84 Trans am
Engine: 355
Transmission: TH400
question..... ive timed a car before but im not sure on this one... is number one cylinder on the driver side or passenger side?
Old Aug 3, 2009 | 04:35 PM
Car: 84 Trans am
Engine: 355
Transmission: TH400
bump^^
Old Aug 3, 2009 | 10:51 PM
#1 is driver's side
in fact. here's a link for reference.
http://boxwrench.net/specs/chevy_sb.htm
Old Aug 4, 2009 | 12:34 PM
Car: 84 Trans am
Engine: 355
Transmission: TH400
awwww so thoughtfull of you... lol jp. hows the cavy doing? clean i hope.
Old Aug 4, 2009 | 01:07 PM
very clean, got an offer from a guy in chicago-ish? and they offered $650, I deliver. not loving the price, but I haven't turned it down either. have someone else interested too. we'll see what happens, cause I'm goin to look at the dsm thursday.
IROCZ1989
Jan 24, 2016 03:55 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
