pushrod mesaurements?
Old Jul 26, 2009 | 08:49 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
i'm getting ready to put the top end on my 305, and i'm hitting a stumbling block.
i need to know if i have to use a special length pushrod for 1.6 rockers?
i'm using a set of ported 416 heads, and a 305 shortblock with a summit 1103 cam.
Old Jul 26, 2009 | 09:05 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: pushrod mesaurements?
Ideally you should use a pushrod checker to determine actual length required if change heads / rockers from stock
Old Jul 26, 2009 | 09:09 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
i figured i would have to do that. looks like i'll have to just put the engine together and find out!
thanks!
Old May 9, 2012 | 07:46 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
I'm hoping someone has a lunati/trickflow combo.... :P
Trick Flow® Super 23® 175 Cylinder Heads, Lunati 85345LUN (3/8th stud, 1.6%), Lunati 268/268 high efficiency cam...
Old May 9, 2012 | 07:50 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
the lift on the cam is .457 and the max lift on the heads is .480 with 1.250 diameter springs. The lifters I'd be using are LUN-72330LUN (summit racing parts number)
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
slowsi
Oct 18, 2015 08:49 PM
mfp189
Sep 27, 2015 09:25 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
