Factory valve guide dimensions?
Old Jul 27, 2009 | 05:39 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
What are dimensions on the factory valve guide? I Bought this set of heads and was told they had already had a valve job done when they were machined for 1.94" intake valves, guide plates and screw in studs.
It looks like the guides are freshly machined as are the the rocker arm stud location. Does it look like I gained any more clearance?
How does everything look? I am hoping I won't need anymore machine work to get ~.500" lift. (Using the appropriate springs)
Old Jul 28, 2009 | 07:44 AM
Re: Factory valve guide dimensions?
Nothing? Somebody has to know what they looked like from the factory!
Old Jul 28, 2009 | 08:56 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
you may have to wait until the weekend people are here. they know a lot about the heads.
what heads are they? the number? the size?
Old Jul 28, 2009 | 02:40 PM
My bad... I guess there are a bunch of other threads here
They definately '081 heads. As far as I know they still have 58cc combustion chambers. You have replied on the other thread concerning these particular heads, if the additional pictures or info can help:
https://www.thirdgen.org/forums/tech...ese-heads.html
Cameeeero
Sep 18, 2015 04:00 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
backtothe80s
Sep 5, 2015 12:39 AM
SlowAZ28
Sep 2, 2015 05:19 AM
camaro71633
Sep 1, 2015 10:24 AM
