mid instal help needed fast air/fuel gauge
Old Jul 27, 2009 | 07:01 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
im working on a friends 85 iroc and we are installing a air to fuel ratio gauge the gauge has 3 wires on the back a red black and green then a black wire with a plastic connecot on the end. i figured the the red is power the black is ground and the green is the acc wire that turns the gauge on when starting. where do i hook the black wire with the plastic connector on the end to? do i hook it to the co2 sensor? if so how? the car is carbed and has no computer in it at all.. please help its getting dark and need to finish
Old Jul 28, 2009 | 11:13 AM
Engine: ls1 soon
Re: mid instal help needed fast air/fuel gauge
update.. ok i hooked up the red wire to power the black to ground and the gauge lit up. i touched the green wire and the gauge started to move ( other lights light up in a circle) could actually control the gauge by how hard we touched the green wire. i then tryed to hook this wire directly to the o2 sensor and started the car. the gauge started going nuts flashing from rich to lean back and forth but not reading a steady reading. the black wire with the plastic connector on the end was left alone. does this have something to do with it not reading a steady reading? or is the grean wire not supposed to be connected to the o2 sensor?
Old Jul 28, 2009 | 01:55 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Unless you are running a Wide Band O2 sensor you will have the "sweeping effect".
Old Jul 28, 2009 | 06:47 PM
Engine: ls1 soon
ok good to know thanks.. will tell him to pick one up
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
IROCZ1989
Jan 24, 2016 03:55 PM
86IROC112
Aug 17, 2015 02:00 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
