Need help diagnosing problem please.
Old Jul 27, 2009 | 09:42 PM
isk8's Avatar
Hey guys I need your help. Today I was leaving my girlfriends and I went to start my car ( 1991 formula firebird, 5.7l FI 350) and it was idling between 1500 - 2k rpm's. It was bouncing quite profusely between them. On top of that it was " jumping " quite bad if I put it into drive. Any ideas what it could be?
Old Jul 28, 2009 | 01:44 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Need help diagnosing problem please.
Check your Idle Air Control (IAC) sensor. It is located on the bottom, passenger side of the throttle body.
In my experience, they can get a carbon buildup resulting in the spring/pintle becoming compressed instead of "springy". This throws off the air reading to the computer.
Hope this helps!
Old Jul 28, 2009 | 04:22 PM
isk8's Avatar
Thanks, I cleaned it out today and its not idling high anymore just jumping a bit when im braking for a while, is this a sign of it going bad and i need to replace it?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
