Car sometimes start sometimes it dosent
Old Jul 29, 2009 | 11:36 PM
elkora90805's Avatar
Car: 1989 Camaro RS
My 1989 camaro 5.0 TBI jut started to have a problem it seems like the battery is dead nd it wont start when i gave it a jump start it kinda hesitted to strt but it started then i turned it off and then i wouldnt start i let it restfor a while and then i tried it again and then its started right up again thats weird i have replaced the alternator i dont know if its the started or the battery or a short somewhere so any help is helpful thanks alot
Old Jul 29, 2009 | 11:53 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: Car sometimes start sometimes it dosent
take the battery and have it tested. just so you can rule that out. i had a similar problem where the car would turn on, but would shut off minutes later, then not be able to be turned back on. turned out the battery was bad. it would have enough to turn the car but it wouldnt take a charge from the alternator.
so once you rule out the battery you can move from there. like turn on the headlights and crank the car while theyre on. if the car doesnt turn on but the lights dimmed. then that means the starter is putting a load on the battery but its not doing anything. usually a bad starter. or if it the lights dont dim you know you have a problem somewhere before the battery. perhaps an ignition switch.
Old Jul 30, 2009 | 12:18 AM
Car: 1989 Camaro RS
yeah i will have it tested 2morrow about and hour ago i try to start it with the lights on and the lights just went out and my battery also
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
kyle5647
Aug 7, 2015 03:08 PM
L98GTA87
Aug 5, 2015 11:02 PM
