Engine Oil Cooler?
Old Aug 3, 2009 | 11:10 AM
bdle's Avatar
Car: 1988 Camaro IROCZ
Axle/Gears: Stock
Engine Oil Cooler?
i just purchased a remanufactured jasper engine 5.7 for my 87 IROCZ. they recommend replacing the engine oil cooler, does anyone know where i can purchase one. they also recommend replacing the harmonic balancer. is this really necessary?? thanks for your help
Old Aug 3, 2009 | 11:24 AM
Twin_Turbo's Avatar
Re: Engine Oil Cooler?
You can't get them anymore I think. Your 87 used a heat exchager w/ hose barbs. The 92 9only 3rd gen year) and 4th gen use one with a hook up style w/ aluminum lines very much like how the AC compressor lines are conencted, 2 lines into an 8 shaped block w/ a central locking bolt. This means, if you can get a new unit for like a 4th gen you will need the 92 lines, haven't seen anyone sell those yet.
Old Aug 4, 2009 | 04:44 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
They only want you to replace the oil cooler to cover their butt's. They think that there could be metal shavings stuck in the sandwich.
Clean it out if you're worried.
Changing the balancer is just a good idea. Not really necessary if it hasn't slipped.
Old Aug 4, 2009 | 06:09 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
If you are set on replacing the oil cooler, Summit Racing has some nice ones. If you want an original replacement, you could look into Classic Industries or Year One.
Old Aug 4, 2009 | 07:47 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i dont even have my stock coolier anymore.. took it out the my new build and got it tuned..... had the fans set a 180 and 200... the engine never sees 200+ temps anymore... if anything its cooler without it....
toronto formula
Nov 10, 2015 06:17 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
Navy8125
Aug 21, 2015 09:32 AM
TreDeClaw
Aug 14, 2015 06:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
