91 V6 No Start problem
Old Aug 3, 2009 | 12:26 PM
joecool108's Avatar
Car: 91 Vert, 69 SS, 91 Coupe
Engine: V8, V8, V6
Transmission: Auto, Auto, 5 speed
Ok guys.. here are the details.. Just purchased a 91 V6, 5 speed for my son, car not running. Car was owned by someone with no mechanical background, they had wire nuts on a cobbled up mess of the starter wires! Anyway after fixing all that and replacing fusible links, replacing wires, etc the motor turns over via a remote starter switch. The next problem is the car wont turn over with the use of the key, secuirity light is always on in the dash, and snap on scanner reads code 46. I pulled the trim panel under the dash to find yet another cobbled mess, There is no clutch saftey switch at all (cant find the plug or the wires to it) there is an orange wrapped set of two white wires coming from the top of the column that have been cut (cant find the other end) and the Vats wires (2 white ones at a small connecter at the base of the column have a GM blank key soldered to them) I told you it was a mess! I measured the key resistance and am going to try to bypass the vats, but any ideas would be helpful to get me pointed in the right direction to get it started.
Thanks!
Old Aug 3, 2009 | 01:34 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
Re: 91 V6 No Start problem
VATS is engaged if the security light is on, get that key blank outta there and put in a resister matching close to the one in the key
Old Aug 3, 2009 | 09:23 PM
joecool108's Avatar
Engine: V8, V8, V6
Ok, got the resistor wired into the vats, got rid of that key blank, now security light stays on for 2 seconds, then goes out (in the on position), still no crank when I go to the start position. But the good news is I hear the fuel pump priming, and then hear a click somewhere under the dash. So Progress! What should I check next?
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
