Wonderbar and Fans don't go well together
I installed this wonderbar a few weeks ago. At that time I noticed it was pushing up against the fan lower mounting points. I didn't think much of it at all. A couple days ago, I got home and noticed all of my antifreeze was pouring out. The fans were dragging on the radiator and it created a large hole. I bought a new radiator. I just installed it. Now I was going to mount the fans, but the mounting points are still too close to the wonderbar. Can you guys come up with a solution for this problem? The wonderbar does not want to budge to give more room for the fans. I trimmed the fan mounts and it still doesn't fit. Can you guys help me out? Sorry for the long read. Here's a pic of the 4 mounting points, I'm referring to. Thanks.
Re: Wonderbar and Fans don't go well together
the only thing i can think of is slotting the holes in the wonderbar a little so it will slide back some. if not then i would remove it so you can drive the xar for now.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
that wonder bar is not designed to clear dual fans, i cant tell what you have.
The stock style, and the one from Top Down solutions does.
Car: 86 Trans Am
i could have sworn i read that on both Spohn and UMI's site a while back, but its not there now. hmmm.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 86 Trans Am
Car: 87 GTA
Can you clamp the mounting tabs on your wonder bar somehow, and then bend them some?
If you can, you might be able to give them a small bend, angling the cross bar down, giving room for the rad fans.
Keep your fans.....Keep your wonder bar..... & a Free fix.
Car: 87 GTA
With enough leverage & clamping force, they'll move.
If your mounting tabs where the bolts go in, they are pretty deep. Much deeper than how tall the bolt heads are. Can you trim the plastic "buckets" down enough?
Slip a flat piece under the wonder bar mounts, to lower it & clear the fan mounts?
Car: 87 GTA
Looking at your pic again.....It looks like you can slot the holes in the mount tabs almost 1/2", allowing it to sit further back, away from the fan mounts.
Car: 1988 Trans AM GTA
Axle/Gears: 9-Bolt 3.27
I know it's an old thread but I bought a Spohn wonder bar and am noticing that the fan brackets in my dual fan setup will now hit the bar same as thelastz28.
Did you have any luck with slotting the holes? Any pics?
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
I have a TDS Wonderbar and dual fans.
No problems at all.
No problems at all.
Yes apparently it's a problem with Spohn. Found in their site instructing to shave the bosses of the fan plastic shroud. Will try that
eightsixseven
Dec 16, 2024 01:50 PM
TA8487
Aug 16, 2015 12:21 PM
