what year did gm offer roller cams?
Old Aug 9, 2009 | 07:05 PM
my86camaro207's Avatar
just wondering what year gm made factory roller cam motors and what they were in and how to tell with out taking the motor apart?
Old Aug 9, 2009 | 07:10 PM
Stephen's Avatar
Car: 87 GTA
Re: what year did gm offer roller cams?
Early 80s in the Vettes, mid & late 80s in everything else.
Quickest way to see at a quick glance, would be by the valve covers on the engine. Perimeter bolts = non-roller engine. Center bolts = roller engine.
Old Aug 9, 2009 | 07:12 PM
so all center bolt valve covers were roller motors?350 and 305?
Old Aug 9, 2009 | 07:16 PM
Stephen's Avatar
Car: 87 GTA
Untouched & from the factory, yes.
Although technically, the heads don't determine the type of cam.
A rebuilt engine could go either way. And there are adapters to put perimeter bolt valve on a center bolt head.
Old Aug 9, 2009 | 09:38 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
nope that is not right some center bolt valve cover blocks that are in trucks are not roller cam motors
Old Aug 9, 2009 | 10:01 PM
Stephen's Avatar
Car: 87 GTA
I think I confused the term "roller" with "hydraulic".
On that note...I'm not sure ANY factory engine (i know zero about LSx though) got roller lifters.
Old Aug 9, 2009 | 10:26 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
https://www.thirdgen.org/1987-chevy-camaro
In 1987, the 215hp 305 TPI motor returned on the newly available 5 spd / 305 TPI combination only. Torque was rated now at 295, up from 275 in 1985. Automatic 305 TPI's still got the weaker cam and 190hp rating. All 5 spd 305 TPI '87 Camaros came with the better cam (25hp advantage) until 1990 when G92 HAD to be specified to get the better cam in the 5 spd 305 TPI. Roller lifters and new valve cover/head design on V8 Camaros. Valve covers featured new sealing and mounting through center of cover.
Old Aug 9, 2009 | 11:11 PM
Guest
Guest
Posts: n/a
1987 was the first year for the factory roller lifters, although they did not use them on everything. Of the ones that did not some have the provisions for the parts to be installed, and some I heard dont even have those. Those are mostly truck applications. Sure way to know is pull the intake.
I guess if you were adventurous with a flashlight and a valve cover off, you could see the guide bars for the lifters.
Old Oct 7, 2018 | 08:06 PM
jugheadsix's Avatar
Dont want to get into trivia here, but you shouldn't say 1987 was the first year GM used roller lifters. My 1918 Buick model E-49 with a jughead 6 has roller lifters. It has overhead valves and the head is not removable so the valve cages come out the top.
I know that's not relevant to modern engines so carry on. But Buick had roller lifters over 100 years ago, if you don't believe me I have the shop manual.
Old Oct 7, 2018 | 08:19 PM
GeneralDisorder's Avatar
The only thing here besides your comments that isn't relevant is this ENTIRE thread from 9 years ago. You dug up a zombie thread. Great job.
Old Oct 7, 2018 | 08:23 PM
jugheadsix's Avatar
Yeah but now everybody is going to read it and say, wow.......roller lifters in 1918? Really? And then I will be the hero know-it-all and win the prize.
junkcltr
Aug 2, 2019 11:12 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
anesthes
Aug 8, 2015 09:37 PM
