Setting timing
Old Aug 10, 2009 | 04:33 PM
Black Z28's Avatar
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
Setting timing
Hey guys, i was jus wondering how do you set your base timing when you have an msd 6al box? i tried setting it but the box jus sets it rite back, it wont let me set it
Old Aug 10, 2009 | 05:13 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Setting timing
The msd 6al box should have no affect on how you set you timing....it does not controll timing itself. Set timing the same way you would always set it normally. If it's moving back then something else is doing it....like you distributor is turning slowly while engine running....
Engine: L98 494hp
Re: Setting timing
are you unplugging the correct single wire timing connector before you try adjusting timing????
Old Aug 10, 2009 | 07:39 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Re: Setting timing
yea single wire unplugged and everything, i turn it almost a quater turn in either direction and it jus bounces back to w.e it was set at
Old Aug 11, 2009 | 11:30 AM
Engine: L98 494hp
Re: Setting timing
okay, and when it's running and you unplug that (brown I think) connector , the check engine light comes on???
Maybe try a different timing gun, or you have something else wrong.
It's just a MSD 6al box, correct?? nothing else with it?? no timing adjusters?? (shouldn't naturally aspirated)
The MSD stands for Multiple Spark Discharge.....it just sparks the plug multiple times, but you shouldn't see that on the timing...the MSD should not have anything at all to do with timing....that is the distributor's job....is it a stock distributor?? I think you have something else goin on....
Old Aug 13, 2009 | 09:53 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Re: Setting timing
yea its jus a normal msd 6al box nothing else than tht, got a rebuilt oem dizzy in it and ive set it numours times before and went fine but wit the box it wants to bounce rite back to w.e i had it before...its weird
Old Aug 14, 2009 | 08:59 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Setting timing
MSD doesn't change the timing. It sounds more like you didn't disconnect the correct wire for the EST. If you're watching your timing on the damper at idle, then disconnect the EST you should see your spark advance drop and not move any more unless you turn your distributor.
If this isn't the case and something else is wrong then you may want to pull your distributor and inspect it closely for problems.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
