idle and stall problem
Old Aug 11, 2009 | 12:12 AM
Camaro Man 02's Avatar
Car: 1987 Camaro IROC-Z
Axle/Gears: Idk
On start up, my LB9 fires then shuts off. Everytime I start it i have to give it a little gas to keep it going. and once its going it idles high. then idles normal after a couple minutes. Then a couple days ago, i was leaving my house and i was going like 10 mph and i let off the gas and it died. Then it did the same thing pulling into work today. Could it be the MAF or IAC going bad or something? i would really appreciate some help on this. thx
Old Aug 11, 2009 | 10:59 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: idle and stall problem
Any trouble codes? If there are none my best guess is the IAC.
Old Aug 11, 2009 | 11:12 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Replace the IAC and reset the idle at 650RPM's. Part costs around $38.00 at any Auto Parts store.
Old Aug 11, 2009 | 05:49 PM
Axle/Gears: Idk
There are no codes, and where is the IAC located and how do take it off.
Old Aug 12, 2009 | 06:28 AM
DJP87Z28's Avatar
If you don't know where it is located and the tools to remove it & reset the idle. Let someone else do it or get a manual.
Old Aug 12, 2009 | 01:09 PM
I believe all the info you need to do it is somewhere on this site? Might wanna try a search for it as i don't remember where exactly it is. Its not too bad but you should probably read over the procedure before you start.
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
