New air intake????? smog legal?
Old Aug 21, 2009 | 01:20 AM
805camaro805's Avatar
Car: 91 Rs Camaro
Engine: 305 tbi
Transmission: 700 r4
I Need some help with this air intake.... help me out, there is no sensor on it so the service engine soon light comes on. I dont think it affects me in any way. But do you think it will pass smog.. and what should i get to get a little more air out of it.
Old Aug 21, 2009 | 01:27 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Won't pass.
Old Aug 21, 2009 | 10:50 AM
Car: 91 Rs Camaro
Engine: 305 tbi
Re: New air intake????? smog legal?
Why not has most smog equipment on there. Put the hose back on it all its missing is the sensor.
Old Aug 21, 2009 | 12:27 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
If the check engine light is on at all... it is an automatic fail.
Old Aug 22, 2009 | 12:39 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Having most smog equipment on there wont cut it. It needs to have ALL the smog equipment on there to pass CA's visual check. To fix the SES light for the missing sensor, you can remove the sensor from your original air cleaner and plug it into the sensor there. Is there a hole in the new air cleaner for it, maybe?
You'll need to put the stock one back on when you go for the test.
Old Aug 22, 2009 | 01:46 AM
Car: 91 Rs Camaro
Engine: 305 tbi
but other than that it shouldnt be a problem to run it around like i have been correct?
I mean for only 5 dollars its a good deal.. And it does have a hole for the sensor
1992 Trans Am
May 10, 2023 07:19 PM
onefreakz
May 14, 2018 12:15 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
kyle5647
Aug 15, 2015 11:56 PM
