Could not remove o2 sensor
Old Aug 21, 2009 | 08:36 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I couldn't turn the o2 sensor when I tried to remove it. I had the special socket, and a breaker bar, but it would not turn. I could have used a piece of pipe as leverage, but I didn't want to apply too much force until I asked someone who knows what their doing.
Old Aug 21, 2009 | 09:00 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: Could not remove o2 sensor
hey try soaking it for two days with wd40. and use the cheater pipe with the breakerbar, and special socket, turn counter clockwise. hard. i didnt have that issue but that just what i would do..
Old Aug 21, 2009 | 09:04 PM
I thought of using a cheater beater pipe as I was giving it a shot, but I just had that gut feeling that something will break. Looking at the new sensor I didn't see what would break, but I just had that familiar gut feeling.
Old Aug 21, 2009 | 09:59 PM
maybe try heating up the car and try it with the breaker bar. but only turn it a mm after you get it just loose. otherwise the air will go into the ehaust pipe and warp the hot valves..but using a propane torch those little cans they use for copper sweating. those work.
Old Aug 21, 2009 | 10:14 PM
Actually the engine was sorta warm. On my first attempt I burned the top side of my hand. I went inside and had something cold to drink, and attempted it 10 min. later. It wouldn't budge. That's when I thought of the cheater pipe, but didn't have the nerve to try it till I had some more info. Maybe it was too cool by then. Did you say a propane torch is a good way to apply heat? I have an oxy acetelene torch, but that might be over kill.
Old Aug 21, 2009 | 10:30 PM
maybe even a little jet butane torch the lighter kinda for ciggs. try soaking it and after a while wipe excess wb 40 and heat it up. but make sure the wb40 fumes evaporate first. and get it hot, then try it other wise propane torch or your torch, its just propane is one part easy and simple to control down to candle flame to a big jet flame.
Old Aug 22, 2009 | 04:22 AM
webeeZ28's Avatar
Car: 1992 Z28 L98 G92
Engine: 5.7 350 B2L
Transmission: 700 R4
I had the same problem on mine using WD40. My friend told me to try this stuff and it worked sooo much better. Spray on and let it soak in. Then try again to break free. This product should be on most of the automotive supply shelves. Good luck.
PB Penetrating Catalyst. Quickly breaks loose the surface tension of frozen parts and protects against further rust and corrosion.
BLASTER PB PENETRATING CATALYST
images/431378.jpg
Old Aug 22, 2009 | 04:33 AM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
WD40 is for lubin your stupid screen door on the house that gets stuck all the time! >>>> PB Blast is for cars <<<<<
Old Aug 22, 2009 | 05:41 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
PB Blaster is great.
If you want to step up to a higher class - get Kroil.
PB Blaster kicks the crap outta WD-40
Kroil kicks the crap outta PB Blaster
You could also heat up the bung and then immediately shoot it with wd-40 or pb blaster. This allows for the cold liquid to quickly cool hot metal breaking the rust seal.
Old Jun 8, 2010 | 02:02 PM
Camatruder's Avatar
Car: 88 Camaro V6
Isn't it dangerous to spray on a hot surface?
I have the same problem and tried everything from Decaltou penetrating oil over breaker bar to heating it up till it looks red. Nothing works and right now I'm kinda ready to bring in the big hammer.
BTW, over here we don't have the penetrating oils mentioned above.
Old Jun 8, 2010 | 02:15 PM
I would just take off the header piper or y pipe, whatever it is connected to and remove it in a vise, with a cheater pipe, counter clockwise. , if it called for 2 foot - 5 foot 10 foot cheater piper, whatever it take to get the job done. Ive broken my temp sender connector fooling around with the 02 sensor (25years old brittle) i man handle everything now. grr
Old Jun 8, 2010 | 02:18 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I use PB almost everyday. Anytime I think a fastener may give me trouble, I soak it before hand with PB. I also use oxy/aceteline to heat stubborn parts and have sprayed PB even on red hot parts. Not sure how effective this really is though. I think it works best just applied to cool parts and allowed to soak. Still though, havent started any fires I didnt mean to start in 30 years. Sorry they dont have PB in Belguim. They must have some brand of penetrant though. I have had to cut out and replace bungs before when 02 sensors have galled into place. I usually get out even the toughest ones with heat and brute force. When penetrant and brute force wont cut it.
Old Jun 8, 2010 | 02:25 PM
i wouldnt spray anything on hot partss, i've seen metal crack after welding, just from a slight breeze. and water or liquids 10/1 thermal cooling to air, id imagine theres there is the chance of exhaust manifold cast cracking. But i do recommend pb blaster even if you got to order it from the states. its up there with best rust stuck thread remover.
Old Jun 8, 2010 | 02:31 PM
Camatruder's Avatar
Car: 88 Camaro V6
Thanks for the replys.
Did some search on the forum here and apperently it's necessary to soak it with penetrating oil for a couple of nights. So I'll try that.
The exhaust pipe is of the car and on the workbench.
The most known make of penetrating oil here is "Decaltou" (and of course WD40). You guys don't know this brand I suppose?
@ Stevolwevol : How did it work out?
Old Jun 8, 2010 | 02:35 PM
Form the left hand steering, and opposite sides of the road. From the accents of english, to the imperial gallons and standard inches, from euros to dollars and coffee to tea. A very different world over here.
Old Jun 8, 2010 | 02:43 PM
Camatruder's Avatar
Car: 88 Camaro V6
I'm not english in fact it's only the third language we learn in school. I really learned it from tv and music so probably i'll have a mix of english and amercian accent.
Btw, we drive on the right side and don't drink tea but coffee (and lots of beer)
Old Jun 8, 2010 | 02:53 PM
its cool. i respect. much respect goes out to you. I love to engineering that comes from over seas, especially BMW. I was merely ramblin on about how its like another world here. A lot of gridlock in euro products. We probably couldnt afford it. What is it every is 1.20dollars/1Euro..
Old Jun 8, 2010 | 02:59 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
A $5 plumbers torch can be mighty helpful, prop it up so the flame tip is on the metal just out the bung, n just watch n wait several mins, then in a loud meaning full maner say "By the power of greyskull" and wrench the sucker lose, and go quick so it can't cool.
Side Effects:
You may also turn into a blonde goddas with big muscle, but it will pass.
Old Jun 8, 2010 | 03:17 PM
Camatruder's Avatar
Car: 88 Camaro V6
Yeah, BMW and VW are german and very good. But I like those ami cars so much and over here a 3th gen Camaro is so rare that it even brings me some status. I understand that in America that is not the case. Talking about different worlds.
Old Jun 8, 2010 | 03:18 PM
the biggest fans of third gens here are Hispanics
Old Jun 11, 2010 | 12:41 PM
Camatruder's Avatar
Car: 88 Camaro V6
I finally got it loose.
I every now and then sprayed some penetrating oil on it for a couple of days. Then I heated it up till it looked yellow and even orange and gave the sucker everything I got in me.
Thanks for the replys. This forum is awesome. Again one step closer to bringing a thirdgen on the road in Belgium.
@Gumby : I didn't so much turn into a blond goddas, but more into a red tomato. But the yelling helped though
SS-EXPRESS
Sep 28, 2015 09:14 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
Night rider327
Sep 16, 2015 02:20 AM
Eric-86sc
Sep 7, 2015 02:10 PM
