coolant temp sensor bad???HELP
Old Aug 22, 2009 | 09:00 AM
89tpirocamaro's Avatar
Car: 89 camaro iroc z28
Engine: 355 carbed
Transmission: t-5 speed
Axle/Gears: 2.73 posi drum rear
my 89 305tpi camaro has a problem. when i first start it up( motor is cold) it drives and runs fine. when i shut the car off and go to start it again (motor is warm) it wont start. its at the shop and they tested the wires that cap on to the fuel injectors and when hot the light is very dim compared to very bright when cold. they just put in a new distributor, ignition coil so its not an ignition problem...... starting to think that the problem is the coolant temp sensor, the wire that connects to it is a little corroded and i think it might be bad itself.....someone please give me some answers so i drive my car
Old Aug 22, 2009 | 10:21 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: coolant temp sensor bad???HELP
does the motor turn over but just not start? do you have a map sensor or maf.?? try checking the grounds for the injectors and maybe even replace the fuses for injectors for hell of it. when it doesnt start, can you hear the fuel pump prime with key set to on position? when they installed the distributor did they time it to specs. how old are the spark plugs? does when you turn the motor over does it act like it wants to start or does sound like its out of gas. Is the whole distributor and it components inside new?
Bstrang6
Sep 8, 2015 04:29 PM
TheExaminer
Aug 26, 2015 04:59 PM
fonzie85
Aug 13, 2015 11:50 AM
