Moly or Cast Rings?
Old Aug 22, 2009 | 10:08 AM
69-er's Avatar
Moly or Cast Rings?
I have an old SBC that is maxed out at 0.60” over. It has about 70,000 miles since it was rebuilt. Several thousand miles ago, I tore down the motor and did a quick hone and ran the motor with no apparent blow-by problems. (On cold mornings, it does sound like a diesel! Piston slap?) I can’t remember what type of rings I used.
For other reasons, I have torn down the motor again and I’m going to try to do a hone one more time. I have no idea what the actual taper is. There is very slight ridge I can feel, with the sides of the cylinders being a little less, so I know there is an out-of-round condition. I can still see a lot of the original cross hatch on the walls, but the pattern is irregular and somewhat patchy.
Since this is not the correct way to be resurfacing the cylinders, I was wondering what would be the best ring to use that could tolerate the irregular wear.
Old Aug 22, 2009 | 12:34 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Moly or Cast Rings?
60 over is NOT maxed out. JE Piston does 65 over, and 70 over. By the way, a 4.070" bore is a 30 over Mopar 340, so you have lots of choices for rings, while at 65 over, you'll have to do JE's rings, or use file-fit rings minus the filing. If that's not in your budget, 80-over cast pistons and cast rings are readily available. They're all dished, there are no 80-over flat tops. But it would be cheaper and easier to just get another block that's already been 30 or 40 over, and make it a fresh 60. Really, you can get a good 350 block for $100 anywhere, they're not scarce nor difficult to get. That would save you the pistons, rings and re-balancing.
Old Aug 22, 2009 | 12:45 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
The cast rings are probably the best way to go. Molyfilled rings do require a near perfect bore and pretty exact finish to get a good seat, but they last much longer when right. In the older bore I'd go with cast though.
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
mfp189
Sep 27, 2015 09:25 AM
6998poncho
Sep 25, 2015 02:56 PM
