New goodwrench shortblock gone bad?
Old Aug 26, 2009 | 03:34 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The engine has < 200 miles on it and I gave it another oil change to switch to a slightly higher viscocity oil. The oil has very, very fine particulate in it. Its not a tremendous ammount, but I can see swirl patterns under bight light when I agitate the oil. I noticed teh same thing at the oil change after I seated teh rings ~50 miles or so. Its not magnetic, so that rules out the rings and just about all of teh valvetrain as teh source of the metal. The particulate is also too fine to be caught by the filter. I opened it up and theres nothing in the pleats.
How much is to be expected on break-in? This is only the second motor Ive ever broken in, so Im not too familiar with what to expect. The engine also ran pretty hot when I first drove it. It ran around 240-250 at times. Its now running at a more reasonable 220 or so during cruising. Do I have a bearing wiping out? Or is this just the pistons being a bit tight?
I was sort of under the impression that after I seated the rings, the engine would be pretty much broken in and wouldnt shed much more metal.
Old Aug 26, 2009 | 04:40 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: New goodwrench shortblock gone bad?
Metal can be expected for up to 1000 miles.
My first build lasted ~800 miles.
My second build lasted ~400 miles.
I wouldn't be too worried yet.
Old Aug 26, 2009 | 02:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Assembly lube will do that.
gta892000
Sep 16, 2015 12:40 AM
Doobie52
Sep 11, 2015 06:19 PM
Nick McCardle
Sep 10, 2015 08:36 PM
z28guy134
Sep 1, 2015 11:50 PM
