Timing Light
Old Aug 28, 2009 | 03:11 AM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
Timing Light
Okay, heres the story. A month ago I decided to pull the distributor off of my 88 camaro and install another one to see if it was the problem. What i didnt do is mark where the rotor was pointed at. So now what im gonna do is do what the manual says and put the engine at TDC and have the rotor pointing at the #1 cylinder. Now my question is i wanna check the timing on my vehicle (If I get it running) after I install the distributor, but the thing is I never used a timing light before. I noticed some of the guys disconnect the brown and black wire by the firewall? Anyways I need some pointers to see if I can get this right. Thanks!
Old Aug 28, 2009 | 04:14 AM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Re: Timing Light
Here's the tech article on setting the timing.
Also, here is a picture of the EST bypass connector (the thing that has to be unhooked when setting base timing):
(Pic borrowed from LT1 Cam Digest)
Note: The exact location of your EST connector may vary slightly from the picture depending on how your wiring harness is routed, but it should definitely be around back of the strut tower/blower box area. Also, it may be completely enclosed in the wire loom, so you might have to dig around a bit for it.
Hope that helps. Good luck.
Old Aug 28, 2009 | 04:25 AM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Re: Timing Light
This will help me ALOT! Thanks for your help man
Old Aug 28, 2009 | 05:57 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: Timing Light
Cali is great. the only place in the world we use the terms (man, dude, sup, killer, laters, bogus, hella, rightious, bummer, bitchen, tight, rad, chill, chillax, kicking it, kick ***, etc)
Isnt Cali great? dude, have a kick *** summer, chilax a little and have a killa time kicking it with the hella hot bitches dude. and man dude, if the bartender is being hella bogus just chill dude your night aint gotta be a bummer. stay tight and drink some killa whiskey, laters.
Old Nov 17, 2009 | 08:19 PM
andetodd's Avatar
Car: '89 IROC 126K 2nd owner.
Axle/Gears: 3.08 limited slip w/ aluminum shaft
Re: Timing Light
Should he have said, "Thanks for your help, sir." ?
Old Nov 18, 2009 | 01:28 AM
Re: Timing Light
youre okay
Andrew6.688
Dec 13, 2015 10:59 AM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Omega
Aug 10, 2015 12:46 PM
Thirim
Aug 9, 2015 06:19 PM
