91 rs idles way to high???????
Old Aug 28, 2009 | 12:56 PM
tkliewer's Avatar
Hey to this web sight, i need tips anything to help my first car smoke people again. She idles at about 3000rpms some times 4000 rpms, sometimes she cuts out, and over heats. if you have any ideas please let me hear em thank you for your time.
Old Aug 31, 2009 | 02:55 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 91 rs idles way to high???????
bizarre! take it to the local GM stealership and pay the $80 for diagnosis.
Old Aug 31, 2009 | 03:30 PM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
umm something holding the gas pedal or the thoratle open? thats what happened on my 88 maro
Old Aug 31, 2009 | 05:50 PM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
HOpe I'm not stating the obvious but I full tune up does wonders and even if it doesn't cure it you will have an easier time isolating the problem. My car idled at nearly 2000 and in thecourse of a good tune up that slowy went to about 800. NOt sure exactly what fixed it but the seafoam treatment had a big effect. Plugs, wires, cap, rotor, timing, air filter, oil, filter, fuel filter, full seafoam to clean the throttle body and fuel system, check for vacuum leaks, PCV valve and breather. check O2 sensor, check throttle position sensor. Even if it doesn't fix the problem the car should run a lot better and you will have eliminated several possibilties. tehere may be several contributing factors. Be sure to do the seafoam BEFORE you change your oil, plugs and especially fuel filter. It will foul them with all the gunk it removes. Also, OBD1 testers are cheap. Check for codes. Good luck! Let us know how it turns out!
Spyder_TheGamer
Dec 25, 2015 05:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
