no power to anything when i turn key to start Help!!!
Old Aug 30, 2009 | 09:57 PM
copperelite's Avatar
Car: 1991 camaro RS
Engine: 305 TBI
Transmission: 5 speed
ive been having this issue for about a month now. 1992 firebird convert. when i turn the key to start it everything dies except interior lights. radio all the lights on the dash shut off. starter is good had it checked. no security light on ever. it has vats system but not hooked up to anything. ie wire harness from 88 camaro w/out vats. and steering column from 1988 camaro no vats. im at a loss with it. please help. any ideas
Old Aug 31, 2009 | 04:30 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: no power to anything when i turn key to start Help!!!
I'm not sure how vats is supposed to work but I know I had to disable it in my prom.
Could be that your battery has internally cracked plates. I had issues like that on a grand am.
Does it start right up with a jump?
Is the braided strap or flat metal piece that goes from your solenoid to starter grounding out against the body of the starter?
Old Aug 31, 2009 | 06:04 PM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
That sounds exaxtly like what happened to my 91 RS> I had the VATS bypassed at teh steering column by soldering in a resistor, but there is a second function in the VATS that I believe disables the fuel pump throuhg the ECM. LIsten to see if your fuel pump runs wehn you turn teh key to "On" (not start) I think if you don't hear it that indicates a VATS problem. I was lucky to know someone locally who specialized in vette and thirdgen electrical. He did some wiring and stuff to bypass. Not sure what. he was under the hood and in the areas around hte VATS and ECM. I think you can also disable it through reprogramming. check sith the folks at tbichips.com or www.hawksthirdgenparts.com. tehy sell a VATS bypass module. Sorry i can't be more specific.
9192camaro
16
Feb 3, 2019 12:21 AM
Jae992
Aug 27, 2015 09:07 AM
wayshegoes
Aug 17, 2015 12:00 PM
tnrednneck
Aug 13, 2015 08:57 AM
ZsTransAm
Aug 11, 2015 07:30 PM
