So I may have messed my heads up
Old Aug 30, 2009 | 08:18 PM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Take a look at this...some damn fool dropped his cylinder head on a bolt and put a sizeable chip in his combustion chamber....
Should I worry about it? If so, how do you folks recommend I fix it? I have a mig welder...if JB weld will work I'll grab some... let me know!
Old Aug 30, 2009 | 08:31 PM
Glenno's Avatar
Car: 1990 Jeep YJ
Engine: 70's 350 w/87 Z TPI-MAP Conversion
Transmission: Muncie SM 465 Granny Low 1st
Axle/Gears: 4:10 Gears in both axles
Re: So I may have messed my heads up
Where exactly? I can't see it clearly. A good machine shop should be able to assess and/or repair easily.
Old Aug 30, 2009 | 08:40 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
It's right on the edge of the chamber about the same width of the fire ring on a head gasket. Agree with getting a shop opinion-if it's not too deep they can mill it. If it's deep both heads MIGHT need milling.
Old Aug 30, 2009 | 08:51 PM
Grumbles's Avatar
BAH i was trying to avoid the shop, guess I dont have a choice now heh.
Wonder if they'll take this set of swirl-ports for a set of 081's or Vortecs
italiano67
Dec 11, 2016 09:21 AM
509 camaro fan
Sep 6, 2015 10:43 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
