im starting to loose hope.... engine runs rough cant figure out why maybe timing???
Old Aug 30, 2009 | 09:52 PM
liteumup387's Avatar
Car: 1982
Transmission: 350
i have a 88 camaro with a 305 tpi... it has no smog no egr (it was like that when i bought it)
the problem im having is the engine misfires at idle and stumbles when crusing when i get heavy on the throttle i really cant hear any misfires or feel the engine stumbling at all
i have replaced cap rotor plugs wires and coil
fuel pressure is 42psi KOEO 35psi KOER 42psi KOER with vac line pulld off the regulator
i really cant find the timing this car likes maybe if some one can give me a course::: engine timing 101 lol im not an idiot but maybe im doin somthin wrong i dont think i am but ive been wrong before lol maybe what i think its supposd to be set at is wrong
other than timing is there anything else it could be
any input would be highly appreciated
thanks,
john
Old Aug 31, 2009 | 06:41 AM
pearlphoenix's Avatar
Car: 86 Trans Am
Engine: 383
Transmission: Probuilt 700r4
Axle/Gears: 2.77 BW 9 Bolt
Re: im starting to loose hope.... engine runs rough cant figure out why maybe timing?
do a search for how to set your base timing, there could be tons of things causing your stumble, look over your vacuum lines for cracks and that there all hooked up with no leaks. are you throwing any codes?
Old Aug 31, 2009 | 08:04 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If the EGR system was not "properly" removed - as in having it turned off in the computer as well as the mechanical parts removed - then it can cause problems as cruise/light throttle RPMs. EGR does not rob any power from the engine though, but will improve gas mileage. I'd recommend reinstalling it and making it functional. It will probably solve a few problems for you, and improve fuel mileage to boot.
If the AIR system is removed and the cat converter is not, then sometimes the cat will plug up, which will cause runnning and drivebility problems. The AIR system also does not rob any power from the engine - it just supplies fresh air into the cat converter to help it warm up faster when the engine is started cold. Without the AIR system, the cat will eventually become clogged because of how inefficiently it works when the cat is cold. You either have to reinstall the AIR system if you keep the cat, or remove the AIR and cat together to avoid/remedy this problem.
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
