Will low vacuum (7-10) affect engine performance?
Old Sep 1, 2009 | 06:10 PM
haysoos's Avatar
Car: 89 GTA
I have low vacuum - around 7-10. This may be because of the larger cam I have in my 89 GTA. I know this is too low for my brakes, so I'm breaking down and buying a vacuum pump to solve this problem. My question is, will this low vacuum affect anything else in my engine?
Old Sep 1, 2009 | 09:01 PM
adams86z's Avatar
Car: 1986 z-28 hardtop
Engine: 355ci w/nos cheater
Transmission: th-350 3300 stall
Axle/Gears: 7.75in 3.70s
Re: Will low vacuum (7-10) affect engine performance?
if you are running a holley carb you will need to run a 4.5 power valve, to keep valve closed at idle. you may have to adjust idle higher and run a higher stall speed converter if it is a auto???
Old Sep 1, 2009 | 11:19 PM
haysoos's Avatar
Car: 89 GTA
i've got a mini-rammed tpi, auto
Old Sep 1, 2009 | 11:21 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
hell yeah that kicks ***
theshackle
Sep 17, 2020 08:26 AM
Infested
May 22, 2018 11:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
NBrehm
Aug 25, 2015 11:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
