Losing my mind
Old Sep 2, 2009 | 08:37 AM
oifivveteran's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Losing my mind
I have a 91 Camaro RS with a 305 TBI. I replaced the Altenator twice the Battery twice new + and - battery cables cleaned all the grounds and it is still not charging the Battery.
Old Sep 2, 2009 | 09:24 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Losing my mind
how about the other, smaller wires to the alternator?
Old Sep 2, 2009 | 09:32 AM
Car: 1991 Camaro RS
Engine: 305 TBI
Re: Losing my mind
The smaller wires from the altenator to the battery are good.
Old Sep 2, 2009 | 09:38 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Losing my mind
no, there should be at least one wire from the alternator that goes inside the car. Pursue both ends of that/those.
Old Sep 2, 2009 | 10:15 AM
rx8ss's Avatar
Car: 1987 Iroc Z28
Axle/Gears: 9 bolt
Re: Losing my mind
Are the failed parts being tested?
When you have your alt/battery replaced, what are they saying is wrong with them?
The small wires that is being talked about are the field excitation wire/s. It senses voltage to know how power to output. If not hooked up/open the alt will not output any power.
tmellott89
Oct 14, 2015 02:06 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Giocio
Oct 1, 2015 12:20 PM
Stryker412
Sep 20, 2015 06:59 PM
