push rod guides?
Old Sep 2, 2009 | 11:14 PM
SanFranCyco's Avatar
Car: 87 GTA
Engine: L98 5.7 24#inj,World hds,MSD,nosmog
Transmission: 700R4 truck clutches,Trans go shift
Axle/Gears: 10 bolt chevy 3.73 limited slip
push rod guides?
i installed used but milled and tested dart heads.They came with push rod guides installed.i noticed some wear on a couple of the new rods.I was wondering if i need the guides or not. and also if there is a way to adjust them as i would like to use them if i could.i have 1.6 compcam roller tip rockers also installed.
Old Sep 3, 2009 | 06:13 AM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
Re: push rod guides?
You need to use harded pushrods when you have guideplates. Are they stock pushrods? If they are they will not work!! Keep the guideplates and buy a set of hardened pushrods.
Old Sep 3, 2009 | 04:35 PM
Car: 87 GTA
their not stock but im pretty sure their not hardened.they were only 40 bucks from comp cam for the set.thanks
Old Sep 3, 2009 | 04:46 PM
NY87Iroc's Avatar
Well they need to be harded for sure to work with guide plates
RedLeader289
May 28, 2019 01:47 PM
grngryoutmyway
Oct 18, 2016 05:48 PM
mrbird
Oct 20, 2015 03:43 AM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
