88 GTA won't start when hot
Old Sep 4, 2009 | 12:45 PM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
I've got a GTA with the 305 tpi and MAF setup. The car starts and runs great as soon as I turn the key when the engine is cold. However, when the engine is hot it will crank all day and not turn over. The only way it will start is if I hold the accellerator to the floor while it cranks. Once I get it started this way it runs fine again. I was wondering if it could be either a fuel pressure regulator or bad injector. Any suggestions?
Old Sep 5, 2009 | 08:35 AM
Vader's Avatar
Re: 88 GTA won't start when hot
Yes, it could be either. Remove the FPR vacuum hose and monitor the port for fuel leakage. If there is no fuel leaking from the FPR, injector(s) leakage is suspect, but verify that with a fuel pressure test.
Old Sep 5, 2009 | 08:45 AM
CjandAlex's Avatar
Car: 91 RS & 88Camaro, 95 Honda Prelude
My V6 3.1L was doing something similar to that. It was 2 bad injectors
theshackle
Mar 5, 2017 06:37 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Street Lethal
Aug 14, 2015 08:25 PM
86Base
Aug 8, 2015 01:34 PM
