opinions/suggestions on engine build
Old Sep 5, 2009 | 09:39 PM
mz-man's Avatar
Car: 91 RS
Axle/Gears: LS 3.73
Hi everyone
I'm looking for opinions and suggestions on my engine build. I posted this in another area, but maybe it fits better here. Here goes...
This is what I have done so far
400 4 bolt main
stock crank reconditioned
stock rods modified for arp bolts
keith black flat top pistons
dart pro 1 aluminum heads 2.05/1.60
lunati bracket master II cam 300 dur .515 lift
team g intake
summit sfi approved damper
Here is what I need, and needing some suggestions on parts
roller rockers - alum or steel? 1.5 or 1.6?
pushrods - chromemoly worth the money?
carb - looking at a plain double pumper holley or bg- 750 enough?
distributor - mechanical or vaccuum advance? which is better for a street/strip engine?
dougs 1 3/4 primary full length headers
looking to rebuild my 700r4 - along w/ 2500-3000 stall
going in my 91 rs - already rebuilt the rear with auburn posi and 3.73 gears. Thanks in advance - Mark
Old Sep 6, 2009 | 08:12 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Re: opinions/suggestions on engine build
Originally Posted by mz-man
Hi everyone
400 4 bolt main
team g intake
Either material is fine. as far as rockers go, I prefer steel, but both will put up with hatever you feel like tossing at them, and one metal over the other isn't a large weight difference as most steel rockers are cast much smaller/thinner than their aluminum counterparts.
Short answer: No. Long answer: Depends on how beefy your springs are going to be, but still in all likelihood, no.
750 will be plenty. Holley's website actually recommends less (650-700) until waaaay up in the 6500's, and with your stock guts, you probably wont be visiting that territory too often.
Often times you can find a dizzy that does both. Personally, I prefer vacuum, as it will advance to where the engine wants it to be, and not a degree predetermined by the dizzy itself.
going in my 91 rs - already rebuilt the rear with auburn posi and 3.73 gears. Thanks in advance - Mark[/quote]
Just my two pennies :]
Old Sep 6, 2009 | 10:03 AM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
i dont believe you will find a dist that has just vacuum advance but just mechanical you probably could find
Terrell351
Jun 13, 2021 01:13 PM
italiano67
Dec 11, 2016 09:21 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
