Knock Sensor Question
Old Sep 7, 2009 | 05:39 PM
Glenno's Avatar
Car: 1990 Jeep YJ
Engine: 70's 350 w/87 Z TPI-MAP Conversion
Transmission: Muncie SM 465 Granny Low 1st
Axle/Gears: 4:10 Gears in both axles
Can a knock sensor be installed using a brass elbow and a one inch straight brass pipe in order to move the sensor away from a header AND still function properly? I can install the knock sensor in the block but it only has a 3/4" space between it and my block huger headers. I fear the plug that attaches to it will melt. Any suggestions or ideas? Thanks Glenno
Old Sep 7, 2009 | 08:08 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Knock Sensor Question
The extension tube will work fine
You can move the sensor to another port on the other side of the block
If that wont work its been moved to the fuel pump block off plate without any ill effects but the best readings are when its in a water jacket
Old Sep 7, 2009 | 08:15 PM
Glenno's Avatar
Car: 1990 Jeep YJ
Other side of the block is even worse. I will look at the fuel pump block off area. Thanks for your help!
Old Sep 9, 2009 | 08:23 PM
Glenno's Avatar
Car: 1990 Jeep YJ
Any one else like to give some thoughts? BUMP.
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
gwade12
Aug 8, 2015 08:17 AM
