what does code 36 mean?
Old Sep 8, 2009 | 02:12 PM
irockz89's Avatar
Car: 89 IROC-Z camaro
Engine: 350 5.7 TPI
Ive got a 1989 Camaro IROC-Z, and i went to start it yesterday and my SES ( service engine soon) light came on...so i used the paper clip trick and i got a code 36...what does it mean..and is it an easy fix..is it safe to drive with a code 36?
Old Sep 8, 2009 | 02:47 PM
irockz89's Avatar
Engine: 350 5.7 TPI
Re: what does code 36 mean?
anyone ?
Old Sep 8, 2009 | 02:50 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Originally Posted by irockz89
anyone ?
You might try the search...
Old Dec 27, 2009 | 04:45 PM
ikeepitreelz's Avatar
Car: 1988 gta-
Engine: 383 tpi
Transmission: 700 r-4
I got the same code and it was an easy fix, if you look by the firewall behind the master cylinder there is a set off relays one being particularly rectangular ,that one is the MAF power relay i changed that one and the other one all the way to the right is the burn off relay i changed that one and so far the light hasn't come back on. Hope this helps each relay is about 12 bucks at auto zone one of the part numbers is MR22. Good Luck.
Old Dec 28, 2009 | 01:20 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
What a code 36 is is a burn off system failure. What the burn off system is, is a system that basically pulses 12V to the MAF after you shut the car off to burn off any crap from the MAFs sensing wire. This keeps it clean and prevents it from reading inaccurate (these sensors are and have to be very accurate thats why there so expensive) due to build up on the wire. So ide deffinetly run through the procedure to troubleshoot it although its not a critical failure running that makes the car undriveable the car like that will eventually damage the MAF because its not being cleaned. Should be an easy fix most likely.
Old Aug 5, 2018 | 07:54 AM
88IROC-USA's Avatar
Car: 1988 IROC-Z
Transmission: 700-R4
Axle/Gears: 2.77 Positrac
Yeah hi guys.
I needs an update in this thread pliz.
Did the relay fix it?
Old Aug 6, 2018 | 08:42 AM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Originally Posted by 88IROC-USA
Yeah hi guys.
well...the thread is 9 years old, and a quick check of the original posters profile shows he hasn’t posted anything to the forum since 2012....so it’s probably unlikely an update is forthcoming.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
