Where do these connect to?
Old Sep 8, 2009 | 06:44 PM
racethesunlive's Avatar
Car: '92 Camaro
I searched but couldn't find a picture or diagram of what lines I should connect these to, they're under the front of the passenger side header.
Any clues at all would be helpful as I'm not quite sure exactly what to even search for...
whatsthispart.jpg?t=1252453296
Old Sep 8, 2009 | 09:31 PM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: Where do these connect to?
It looks like your car originally had an oil cooler and those would be the coolant tubes to it. There should be a bracket that holds them to the fuel pump boss then they wrap aroundthe drivers side to the adaptor above your oil filter.
Old Sep 8, 2009 | 10:45 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
mechanical fuel pump? hard to tell with the pic
Old Sep 9, 2009 | 01:04 PM
Car: '92 Camaro
The camaro has been running for several months now with these ports open like in the picture. They do put out some hot air but would it be safe to just plug the ports if they were from an oil cooler? That was the best picture I was able to take considering these tubes run underneath the engine.
I appreciate any and all help!
Old Sep 9, 2009 | 02:02 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I'd say oil cooler as well. Jack the car up and get under the car, trace these lines, figure out where they DO go to. Otherwise capping them may be bad, since air is coming out you don't want an unwanted pressure of air building up around the motor, could be bad in doing so. Jack the car up, follow them and let us know, maybe take more pictures while under there.
It could possibly be a mechanical fuel pump, using 2 hard lines coming to and from the pump? Only way to know is getting under there or taking a better picture with some light under the car or something to brighten that area up.
Let us know.
Old Sep 9, 2009 | 02:18 PM
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 10 bolt 3.73's
Those are for the oil cooler. You can leave them just the way they are. I had leave mine out when I replaced my engine. The old engine had a knock so there was alot of metal and bearing material in the oil, and alot of that gets stuck in the oil cooler. Tried to get a new one but GM discontinued that part. Coolant runs through one line down to the oil cooler above the oil filter, then back up through the other line.
InfernalVortex
Apr 20, 2021 11:31 AM
bplessy
Sep 30, 2015 12:14 PM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
