engine will not shut off when key in off position after 350 swap
Old Sep 8, 2009 | 10:07 PM
ziggy56's Avatar
engine will not shut off when key in off position after 350 swap. I think it has something to do with the dizzy. I just took a wire and put one end to the dizzy and the other to the alt. but i noticed on the other cap on the v6 It has to plugs, one with 2 wires one with 4. would this have something to do with my car not turning off when i put the key in the off position ? if not anyone know what would be causing it ?
Old Sep 8, 2009 | 10:42 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: engine will not shut off when key in off position after 350 swap
i am going to guess you now have a carbed engine... and of course it wont shut off you have wired the dist straight to the battery you should be using the wires off of the old coil to power the dist just cut the connector off i used spades and hooked them up to the dist that way you only get power when the key is on....
Old Sep 9, 2009 | 08:35 AM
ziggy56's Avatar
yes went from 3.1 fuel injected to 350 carbed. thanks for the reply i will do that. Have never had a car with a wire harness so switched it over to carb, am horrible with wiring. :P
Old Sep 9, 2009 | 09:16 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
LOL, they don't call it the ignition switch for nothing.
Old Sep 9, 2009 | 11:53 AM
fleetmgr's Avatar
You could always just pull the coil wire out when you want to shut if off.....it only hurts for a second.
Old Sep 9, 2009 | 08:57 PM
ziggy56's Avatar
oh well i couldnt find it, will have to take some time asside to sort out all the extra wires under the hood. put a toggle switch on the dizzy wire for now. seams to work well.
Old Nov 7, 2018 | 11:18 AM
T-IROC87's Avatar
good idea!
bellez77
Sep 5, 2015 08:39 PM
Tonyy_z
Aug 12, 2015 07:20 AM
armybyrd
Aug 10, 2015 09:23 PM
Kaweh
Aug 9, 2015 02:54 PM
gwade12
Aug 8, 2015 08:17 AM
