Starter Keeps shorting out
Old Sep 20, 2009 | 10:48 AM
slw87's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: T-5 borg warner
Axle/Gears: 3:45
I keep having problems with starter solenoid shorting out on my car and then the car looses power to everything. I mean, no lights, no radio, nothing works. Not even the accessories that are directly hooked up to the battery. Now once i remove the wiring from the starter, everything works again, but it you touch the solenoid. Everything goes out again. I've been through three starters this year and havent been able to figure out why the solenoid keeps shorting out. I know there's a small chance that i could be getting bad starters, but i want to check out all my options cause the tow bills arent cheap. If anyone had a suggestion, please help. Thanks.
Old Sep 20, 2009 | 11:19 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: Starter Keeps shorting out
I'm betting you have a blown fusible link, or a burned out ground strap from the battery to the motor.
mcbitchman
Sep 30, 2015 01:00 PM
mcbitchman
Sep 29, 2015 12:32 AM
J.C. Denton
Sep 21, 2015 04:23 PM
sahlomonic
Sep 20, 2015 07:15 PM
Formula_88AE
Sep 3, 2015 01:47 PM
