Comp cam
Old Sep 21, 2009 | 09:35 AM
TransAm_85's Avatar
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
Axle/Gears: Borg warner 3.08's
Comp cam
I just bought a engine. It has a comp cam and comp cam double valve springs. Do i have to remove the inner valve springs when breaking in the engine? What would be the best way to remove them? Thanks
Old Sep 21, 2009 | 12:07 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Comp cam
yes, you have to. As for how, do you want to do it the cheapest way, the easiest way, or the best way?
Old Sep 21, 2009 | 12:19 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: Comp cam
I think that if you have a roller cam, you don't need to remove the inner springs during break-in. A non-roller, I'd think that you do need too.
Old Sep 21, 2009 | 01:14 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
Re: Comp cam
this man speaks the truth.
Old Sep 22, 2009 | 08:50 AM
TransAm_85's Avatar
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
Re: Comp cam
It has a flat tappet cam. How do i remove the inner valve springs? My dad said to rig up a rubber peice on the end of a air gun and remove the spark plug and pressureize the cylinder so the valve wont fall out. What do you guys think?
Old Sep 22, 2009 | 11:14 AM
mnorton's Avatar
Engine: 305 LB9 TPI
Re: Comp cam
Yes you need too pressurize the cylinder with air. I used an air hose that is part of a cylinder compression tester kit. It worked well.
Old Sep 22, 2009 | 11:37 AM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: Comp cam
Works very well!
I have done the same for many spring swaps and valve seal replacements.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
sandman92084
Sep 12, 2015 10:27 PM
Strick1
Sep 4, 2015 07:11 AM
