Head bolt Torque Value
Old Sep 22, 2009 | 02:11 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys,
Since I am replaceing my valve cover gaskets and have the valve covers off, I figure I might as well torque my head bolts. Does anyone know what they should be torqued to? It's on a chevy 350 with World Sportsman II heads. Thanks!
Old Sep 22, 2009 | 02:46 PM
grumpyvette's Avatar
Re: Head bolt Torque Value
http://boxwrench.net/specs/chevy_sb.htm
http://forum.grumpysperformance.com/...hp?f=50&t=1222
Old Sep 22, 2009 | 04:21 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Thanks for the link, but I don't see that many bolts to tighten...do I need to take off the intake manifold as well?
Old Sep 22, 2009 | 06:01 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
9 are under the valve cover and 8 are below the exhaust ports. Unless you just put the heads on recently, I wouldn't mess with it.
there are exactly that many bolt on a sbc head
#s 1,2,5,9,13,17,6,10,14 under the valve cover
#s 3,4,7,8,11,12,16,15 are along the lower outer head under the exhaust manifold or headers
Old Nov 7, 2009 | 12:59 PM
XxodinxX's Avatar
Hey, i am replacing my bolts and found the sequence here, but There are 3 lengths of bolts, i know the longest should go up top and the shortest goes on bottom, but there are 2 mid length bolts. Where do those go?
Old Nov 7, 2009 | 01:14 PM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
the mid length bolts would go into numbers 17 and 14 in the diagrams posted in this thread.
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 25, 2015 12:54 AM
86White_T/A305
Aug 17, 2015 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
