85 camaro help
Old Sep 22, 2009 | 09:11 PM
sloatgnc's Avatar
Car: 1989 chevy camaro
Engine: 305 tbi
Axle/Gears: 2.73 gears
85 camaro help
i have an 85 camaro that stays running for a minute after ke is shutt off what could cause this i replaced the key switch didnt fix it and my tach reads 4500 at idle and 0 oil pressure please help
Old Sep 23, 2009 | 10:01 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 85 camaro help
does it continue running smoothly, or does it start sounding like a poorly-idling diesel engine being lugged? The answer to this will tell whether the problem is engine related or electrical.
Old Sep 23, 2009 | 03:27 PM
sloatgnc's Avatar
Engine: 305 tbi
Re: 85 camaro help
it gets sluggish and sometimes sounds like a diesel
Old Sep 24, 2009 | 10:17 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 85 camaro help
either your ignition timing is wrong, or you have carbon buildup in the combustion chambers, or both. When there's carbon, it stays hot enough to keep igniting the fuel, even without the sparkplug firing.
Old Sep 24, 2009 | 12:24 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: 85 camaro help
Dieseling is typically due to leaking injectors/whatever fuel system you have.
Old Sep 24, 2009 | 06:24 PM
sloatgnc's Avatar
Engine: 305 tbi
Re: 85 camaro help
oh ok thanks for the help i am putting new wires,plugs,cap, and rotor on today.Then i am going to change the carb but now what could be the problem with the tach and oil pressure gauge
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
