Special Tool to Remove Treaded Plug from Head?
Old Sep 23, 2009 | 09:54 PM
86WS6's Avatar
From: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
Does anyone know if there is a special tool made to remove the treaded plug from the passenger side head on a 305? My car is an 86 with TPI, an F code engine. The OEM fan switch is located on the front of the intake manifold just above the water pump. I want to install an aftermarket fan switch in the passenger side head.
The plug has a square hole in the top. It is smaller then a 3/8 drive, but larger then a 1/4 drive, somewhere around a 5/16, but could be metric. I tried grinding down a 3/8 drive on a 1/2 to 3/8 adaptor, but it twisted off of the socket with pressure applied. There should be some sort of socket made with a case hardened 5/16 bit that will fit this plug. I ahve not been able to find one.
Thanks in advance,
Charles
Old Sep 23, 2009 | 10:12 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Special Tool to Remove Treaded Plug from Head?
yes there is a special tool for those plugs. Finding one is possible but it would be through someone like Mac, Matco, or Snap-on. I borrowed a socket from a guy I knew and it was too tight. I just rounded out the sqaure in the plug.
Old Sep 26, 2009 | 11:37 AM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
I tried to remove mines on a rebuild...but I broke my friends tool....darn.
It was a 5/16 allen wrench socket...a pretty tough tool at the best of times.
I believe it's sealed in pretty good and heat will be required to remove it.
I just gave up on it. If I need to remove my heads for any reason I will strive to get it out.
meanwhile I found a reducer to fit my egr thingy place on my water outlet and inserted the sensor in there. It is to control the engine fan if I recall.
Old Sep 26, 2009 | 12:37 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
You can order the socket from Snap On. It's the next size smaller than the 3/8" square drive. I gave up trying to remove mine while the engine was in the car for fear of stripping it out. When I pulled the motor last Summer I was easily able to remove it with the drive while the motor was on a stand.
Old Sep 26, 2009 | 08:49 PM
chopper1's Avatar
this might sound kinda funny but if you have a pipe plug thats to tight to remove try to tighten it first it will move and then remove it if its a oring type plug rap it with a hammer first and then remove it
gta90
Sep 15, 2015 04:00 PM
backtothe80s
Sep 5, 2015 12:39 AM
TheExaminer
Aug 25, 2015 07:34 PM
camaroken83
Aug 10, 2015 11:35 AM
3rdgenparts
Aug 8, 2015 07:09 PM
