TPI cuts out
Old Sep 25, 2009 | 11:08 AM
detroit305's Avatar
TPI cuts out
Running out of ideas, can someone help: 86 305 TPI, original owner, 54,000 miles. Engine wouldn't run after start and key return to run position, concluded was only running on cold start injector. Steady 42 psi fuel pressure. No trouble codes. Installed reman ECM, engine would then start and run, however idle higher than normal with periodic large drop in idle speed to almost stall and then resume, after 5 min or so complete stall. On road engine cuts out and resumes. Still no trouble codes. With IAC disconnected same symptoms but even higher idle speed, with MAF disconnected same symptoms but rough running engine. Removed belt from alternator, same symptoms. Volts at battery steady 13.8 with engine running. Clean tight ECM ground at back of DS head. In diagnostic mode various relays etc start and stop at random, check engine light erratic. Haven't been able to reactivate my old Diacom software so hoping someone has seen this before. Thanks
Jeremys87
Jul 14, 2022 09:08 PM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
Caspar
Jun 19, 2016 11:19 PM
Winchester1094
Aug 18, 2015 10:23 AM
Sanjay
Aug 12, 2015 03:41 PM
