350TPI Starting problem
Old Sep 27, 2009 | 10:42 AM
IROC-ZeeUK's Avatar
Car: 92' Z28
I’ve just bought 1992 Z28 with a 350TPI and 700R4 transmission. When I go to first start the car with the shifter in “Park” I turn the key, the dash lights come on and I just get a “clonk” sound and the engine doesn’t turn over. I found that taking the shifter out of park, in to neutral and then back into park the car starts fine? The battery is almost brand new and the car always starts, either first time or after I’ve taken it out of park worked the shifter back and forth.
Ideas please? I don’t think it’s the starter because the car has only done 35,000km!
Old Sep 27, 2009 | 11:48 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: 350TPI Starting problem
Sounds like the switch on the side of the shifter that allows it to start in park or neutral only.
Take the console apart, you will see the switch on the side of the shifter body. It has large purple wires running into it.
Old Sep 28, 2009 | 11:16 AM
IROC-ZeeUK's Avatar
Car: 92' Z28
Cool thanks, I will take a look next time I use the car.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1989formula5.7l
Aug 15, 2015 11:35 AM
92camaroJoe
Aug 13, 2015 06:07 AM
