GOING TO TPI
Old Sep 29, 2009 | 04:19 PM
s-dimex8's Avatar
Car: 87 camaro RIP
Engine: 305 cc carb
Axle/Gears: L if i know
GOING TO TPI
im going the opposite way than most do withthese swaps.
i am planning on going from a computer controled carb to a tpi system,
am purchasing the complete setup tomorow, aside from a fuel puimp what else will i need, its going on a 305 H.O. that im putting into my sdime since my maro fell victim to the ice storm earlier this year. the setup is complete with all sensors, rails, injectors, harness and ecm. just trying to get my ducks in a row, so there is less cussin if any when i turn the key
also plannoing on using a comp xe270hr cam, any issues with the stock heads and wanting to use 15 intake and 1.6 exhauts rockers if poss
Old Sep 29, 2009 | 09:35 PM
RobSS1113's Avatar
Re: GOING TO TPI
i did that once.. I thaught all i needed were some little things turned out I needed ALOT of stuff !!!!! and it cost WAY Too much ! I would never do that again .. I would just go and buy a car with that type of motor in it already cheap.
Old Sep 30, 2009 | 08:12 AM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
Re: GOING TO TPI
Try this, lot's of info there. http://www.v8s10.org/forum/viewforum...ec2d4d9b80b05b
Old Sep 30, 2009 | 09:50 PM
s-dimex8's Avatar
Car: 87 camaro RIP
Engine: 305 cc carb
Re: GOING TO TPI
thanks for the input guys i do owe you thanks
SDIME
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
