horsepower and torque help
Old Sep 29, 2009 | 09:10 PM
schottout's Avatar
ive got a 350 bored 30 over with vortec heads flat top pistons stock rods and crank shim head gaskets a comp cams 270h cam summit vortec style intake manifold holley 650cfm with vac sec headers with 2 1\2 inch duals with with flowmasters that dump before the rear im just looking for an educated guess if more info is neaded just ask thanks
Old Oct 1, 2009 | 10:59 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: horsepower and torque help
Probably just over 350 HP, that's a way wrong cam for those heads. Those heads have really poor exhaust ports, and thus need extra duration on the exhaust lobes of the cam. You shouldn't be running more than 32 degrees of total timing at WOT. About 8 degrees initial, and another 24 of centrifugal. If you want more, get an XE268 cam.
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
