HELP ME PLEASE 350 trouble
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
i changed the lifters in my car. so i had to take the distibuter out. we put everything back and retimed the car. went to top dead center and turned the distributer to no. 1 it would start up and idle on occasion with the fuel line off but when you plug it up it just floods right know most people would say o the carb. float in it to be exact i went and bought a new refurbashed carb and still it would only run on starting fluid. please help me you can email me at red92z28@aol.com thanks
car is an 87 trans am with an older style 350
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: HELP ME PLEASE 350 trouble
the float in the carb requires you to have less than 7 psi of fuel pressure into the carb, while your in-tank electric pump is pushing alot more than that. get a return-style fuel pressure regulator.
Car: 1992 Camaro
Transmission: t-5
the thing is everything worked fine before i changed the lifters and it dont have an i tank fuel pump its on the side of the block. thanks for you help would the fuel pressure regulater still work?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Just because you bought a refurbished carb doesn't mean it's had it's floats adjusted - it just means it's been taken apart, new gaskets, and new parts if needed, and put back together. Adjusting floats has to be done on the car with gas in the carb. Same as other adjustments. Why does everyone think a fix comes in a box? Get your hands dirty, get a screwdriver, a book, a beer - whatever, and get in there! Can't learn unless you just do.
Car: 1992 Camaro
Transmission: t-5
i got all the books and plenty of beer and checked the floats there all good still not sure what it is.
