Paper towel in my #1 cylinder...Timing?
Old Oct 6, 2009 | 10:55 PM
SoSoFresh_SS's Avatar
Car: 1984 Firebird
Engine: 2.8L V6
A guy at work told me to find TDC seting my ignition timing, I can stuff a paper towel in my #1 cylinder and crack the engine until the paper towel pops out and that'll get me close enough to set the timing from there.??? How true is this?
Old Oct 6, 2009 | 11:32 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: Paper towel in my #1 cylinder...Timing?
i wouldnt. I would pop a valve cover and watch the valvetrain.
Old Oct 6, 2009 | 11:35 PM
Car: 1984 Firebird
Engine: 2.8L V6
I guess that would work too. I was just wondering if anyone ever attempted the paper towel trick
Old Oct 7, 2009 | 01:59 AM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
pull the spark plug. put your finger over the spark plug hole. rotate the crank with a wrench from the crank pulley. when the compression pushes your finger off the hole, the cylinder is at TDC.
Old Oct 7, 2009 | 04:30 AM
Richwiz1's Avatar
Or you can a bud to bump motor or use remote starter switch .Dont trust paper towels.
Old Oct 7, 2009 | 10:42 AM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
I wouldn't trust cheap paper towels...but a good name brand roll...that should do the trick.
I'm on the 'put thumb over hole, rotate with a wrench on crank pulley' crowd on this one. More precise than using the starter motor...who knows where its going to stop.
Cleotiz
Jan 6, 2018 08:56 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
Logan Bryant
Sep 23, 2015 06:51 AM
alpine247
Sep 16, 2015 05:25 PM
TomP
Jun 23, 2001 09:20 AM
