Is my EVAP Control System set up right?
Old Oct 9, 2009 | 01:13 PM
YoungMoneyVII's Avatar
Car: 1990 Pontiac Firebird T-Tops
Engine: V8 350 5.7 L TPI
Transmission: Overdrive 700R4 (Auto)
Axle/Gears: 9 Bolt/GU5AXLE,REAR3.23 RATIO3.23R
On my EVAP cannister the hose that leaves the Inlet air goes to a 3 way hose splitter and the other two hoses that leave the splitter just go to nothin. My car was very jerry rigged when i got it so i just want to make sure my EVAP system is set up properly or this is a problem?
you can see the spot in talking about in the bottom left at the edge of the reserve tank.
Old Oct 9, 2009 | 06:31 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Is my EVAP Control System set up right?
http://www.chevythunder.com/fuel%20i...INE%20DIAGRAMS
1992 Trans Am
May 10, 2023 07:19 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
lakeffect2
Aug 23, 2015 08:44 AM
Street Lethal
Aug 13, 2015 08:28 PM
