Spark plug wire holders with C/bolt heads?
Old Oct 10, 2009 | 02:45 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
What are you guys using to support / route your plug wires with aftermarket centerbolt heads that don't have provision for the stock wire holders; especially with thick wires?
New MSD setup is blowing out through my old stock wires and don't want to burn up my nice new Accel 300+ 8.8mm set
Old Oct 10, 2009 | 09:01 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Spark plug wire holders with C/bolt heads?
That's a very good question. Not much is said about that topic. Too many times it's: "stick the plug wires on it and let's take it for a test drive". They never get finished up.
I'm not running center bolt V/Cs but THESE are the only ones I see that I like. Lots of places to snap the wires in = good.
They have them in diferent colors besides blue.
Old Oct 10, 2009 | 09:29 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Its where to mount them that's the problem.Only solution I see is to replace a couple of valve cover hold down bolts with studs so I have a fixing point ?
Old Oct 10, 2009 | 09:37 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Lots of centerbolt cover wire looms available at Summit.
Old Oct 10, 2009 | 09:38 AM
Engine: 350 4BBL
They should just take the place of the flat washer under the bolt head. You may need to go with a little longer bolt...
Old Oct 10, 2009 | 06:12 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
http://estore.websitepros.com/2120533/Detail.bok?no=76 check this out they have a few different versions available. just ck the site. hope this helps. im doing this to my 96 next time wires are required.
Old Oct 10, 2009 | 06:16 PM
try this link too it shows the kit better, you get the idea, just get the looms if ya have the wire set already. http://estore.websitepros.com/2120533/Detail.bok?no=69
Old Oct 10, 2009 | 06:32 PM
Engine: 350 4BBL
Those look damn nice! I wonder why JEGS doesn't carry them? O/T: what year is the road runner?
Old Oct 10, 2009 | 06:44 PM
its a 69. 4 speed car.
Old Oct 10, 2009 | 07:15 PM
Engine: 350 4BBL
Ah. The one on our "Do not race" list, back in the day... evil mopar.
Old Oct 10, 2009 | 07:20 PM
ahhh but she is a sweet ol' brick. gotta love the volume these cars took up compared to a 3rd gen. (i like my 85 alot btw)
Old Oct 10, 2009 | 08:58 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
check this out they have a few different versions available. just ck the site. .
Found these for retainers only
http://www.summitracing.com/parts/MFY-5035613/
Old Oct 10, 2009 | 09:13 PM
Engine: 350 4BBL
They gonna work with the 8.8mm wires?
Old Oct 10, 2009 | 09:26 PM
welp-yes if msd's fit, accels will fit as well. .3 mm is a small difference. are we all are on the same page?-hope it helped you solve yer dilemma. pass the info on to others that need it.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
djmarch
Aug 9, 2015 05:27 PM
