Ignition Switch help.
Old Oct 11, 2009 | 07:49 PM
Waymores's Avatar
Car: 89 Camaro
Engine: 350 TBI
Ok, im attempting to change out my ignition switch. Got the steering column dropped, got the switch unbolted, but cant seem to get it out. This is probably a dumb question, and i apologize if its really simple, but how do i get that cable Disconnected from the back of it, not the rod from the ignition but on the other side? I tried pushing it (it seems like i should just push it in) and pulling. Is there like a release button on this thing that i cant find?
Old Oct 11, 2009 | 08:55 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Ignition Switch help.
Have no idea if it's the issue you are having, but have you tried inserting the key and turning it to the on position? I've read a few posts that suggest the key must be turned on for removal - which kinda doesn't make sense 'cause most folks replace the ignition because the key doesn't work anymore - but it was a thought I had.
Old Oct 16, 2009 | 01:41 PM
lwsills's Avatar
Car: 89 IROCZ
Engine: 5.7 tpi
Axle/Gears: 9 bolt borg-warner 2.77 posi
Key does need to be in the run position for easy removal.
and dont forget to disconnect the vats wiring before pulling it out too far.
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 18, 2015 02:28 PM
djmarch
Aug 9, 2015 05:27 PM
