help, wont start after 5 speed swap.
Old Oct 12, 2009 | 02:22 PM
white devil's Avatar
Car is an 86 iroc z. Was an lb9/700r4. Car ran great before the swap, allways took a bit to start when cold, but ran pretty good. We swapped to a t5, nuetral safety switch is wired up, and will turn over. Car IS getting fuel, shrader valve shows it, and I can smell it as well while turning it over. Car IS getting spark, but seems "lame" when i put a plug in a wire and turn it over.
I don't get it, its got a new cap/rotor/plugs/wires and I am pretty sure that we did the tranny swap exactly how we should have. It just turns over and kind of "hiccups" here and there with a slight back fire. What should I check? I am beginning to think its ecm related.
Thanks in advance guys.
Old Oct 12, 2009 | 02:59 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: help, wont start after 5 speed swap.
Sounds like the timing is off. Did you take the distributor out? It may be off 180 degrees.
Old Oct 12, 2009 | 03:02 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
I agree with Jv9999, sounds like you are 180* out
Old Oct 12, 2009 | 04:02 PM
Never took the dist out.... has a new coil as well. Its strange, it ran fine before. Now, as I turn it over, it barly back fires, and just sounds odd. It has fuel and seems to have spark, enough to slightly ignite, but like at the wrong time. All I did was take the cap off. That's why I am thinking it might be the ecu or something of that nature. Any other ideas on what I should check? Timing should have never changed.
Old Oct 12, 2009 | 04:07 PM
However, with the cap off, I had to "key" the motor to turn it over a few times to pull the old tq converter out... that wouldn't have an effect on it would it? I wouldn't think so.
Old Oct 12, 2009 | 04:08 PM
jv9999's Avatar
Engine: 5.7L/350
Did you mash it against the firewall? Damage the cap? Easy to do while swapping the trans. Stills sounds ignition related to me.
Old Oct 12, 2009 | 04:38 PM
cusec's Avatar
Car: 1991 RS
Engine: 383 MAF TPI
Transmission: Richmond 6 speed
Axle/Gears: Moser Ford 9 inch
Is the distributor loose? If so you could have twisted it while changing the cap which would throw your timing off. Did you double then triple check your spark plug wires to ensure that they are installed in the correct firing order and in the correct position on the cap?
Old Oct 12, 2009 | 05:09 PM
I had removed the cap before pulling the tranny to insure that no damage would have took place. I had checked the wires for correct placement like 10 times and even moved them around as well (all of them clockwise and counter clock wise) and it literally. Made no differece what so ever. Same dumb hiccup sound and will NOT fire up. The distributer seems tight, and does not look like it moved at all. Everything looks the same. I'm going to try an install the old distributer and see if it makes a difference, the car ran great before the swap, however, the car did sit for over a month as I was gathering parts.
Old Oct 13, 2009 | 01:33 AM
Update. I played with it again tonight, put the other cap on, and still no start. Went back to the new cap, rotor, and coil, and still no start. I tested the plug wire again with another plug and turned it over and now there is no spark, and the back fire sound is gone. Just turns over. I am thinking internal parts of the dist are shot. I am hoping for a simple fix....
Orr89RocZ
Apr 25, 2016 08:28 AM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
jbd1969
Aug 17, 2015 07:06 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
