This broke, kickdown cable? Pic inside
Old Oct 18, 2009 | 07:06 PM
2LTCamaro's Avatar
Ok this black clip broke. Can I replace the clip? I was thinking about a 2 part epoxy fix. If I replace the whole cable is it hard? Is it a kickdown cable? Also could this be the reason why my car shifts really slow (feels like slipping) and when it shifts it shifts hard, shakes the whole car. Thanks for the help!
Old Oct 18, 2009 | 07:19 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: This broke, kickdown cable? Pic inside
If you're running a TH700, that cable affects hydraulic pressure in the trans. I wouldn't drive the car with that cable disconnected from the throttle linkage.
Old Oct 18, 2009 | 07:25 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
One way to torch the trans
Cable can be replaced by unbolting from trans; I don't think epoxy is going to last
Old Oct 18, 2009 | 07:26 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
dont drive the car dude. replace the cable,
Last edited by transam85dudeman; Oct 20, 2009 at 10:13 AM. Reason: dont drop the pan*edit
Old Oct 18, 2009 | 08:14 PM
2LTCamaro's Avatar
you kidding me? Ugh been driving the car like that for a week. Just did a tranny flush and filter change as well. Only a small pice of plastic broke off the lip of where it connects, i hope the epoxy will hold till I can do this. Crappy old car!
Old Oct 18, 2009 | 09:06 PM
Damon's Avatar
If there isn't enough plastic left to keep it on the stud, yes, you need to replace it pronto. You can smoke the tranny in very short order without it hooked up (and properly adjusted!). It affects the line pressure inside the trans, among other things. That means internal slippage can result- which wears stuff out in a right quick hurry.
It's not a big deal to replace it. Yes, you have to drop the trans pan. That's how you get to the other end of it where it attaches to a little arm inside the trans. Other than that it's a "clip it in the brackets" kind of affair.
Remember to go through the proper adjustment procedure on the cable head after you install any new cable. Yes, there is an adjustment. Too loose and it shifts early plus the potential again for trans slippage. Too tight and you'll never get to WOT when you lay the pedal all the way down.
Old Oct 18, 2009 | 09:34 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Agreed! You'll ruin the tranny - DO NOT DRIVE unless you want to dish out $1000 for a rebuild! Replace that cable - dealer carries them as well as most parts stores. No epoxy will hold it - way too much pressure on it. It's called the TV cable - do a on here to see how to properly adjust once you get it replaced - 'cause a wrong adjustment is as bad as not having one at all.
Old Oct 19, 2009 | 04:11 PM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Why would you have to drop the pan? I was able to replace mine by removing the tranny crossmember and driveshaft. I then slowly lowering the transmission using a floor jack until I could reach the cable with my hand. I removed the the cable, installed the new one. It was tricky to get the clip in but is doable and then installed everything in reverse. It took me about an hour total.
Am I missing something here? I am by no means a professional but hate this guy to go through trouble he does not have to.
Old Oct 19, 2009 | 04:33 PM
Car: 1992 RS
Engine: Carbed 350
You don't have to drop the pan - I never did. Like stated, you may need to lower the tranny by removing the bolts from the crossmember and let it down on a jack - not sure I'd even remove the drive shaft as it will move on it's own (U-Joints). Inside the tranny there is a small pin - on the TV cable there is a small hole - the hole goes over the pin, then there's only one small bolt that holds it on - the trick is to get the hole in the cable end onto the pin and get it secured without the pin slipping loose. Definitely do-able under the car on jack stands without dropping the pan.
Old Oct 20, 2009 | 10:13 AM
yeah dont drop that pan.! my bad. dont.
Old Oct 20, 2009 | 10:16 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
The cable isn't too hard to replace, but it's a little tricky getting it connected. The pan does not have to come off. It goes into the passenger side, downwards into the lower part of the trans. It hooks to this little clip thing, and it's kind of a pain to get it connected, just because it's down in a hole. Needle-nose pliers, or even tweezers should help. My buddy and I spent a good hour or so when changing his car from TBI to TPI, and swapping to the TPI TV cable.
Old Oct 25, 2009 | 07:25 PM
xbox07's Avatar
Car: 86' Z28
Axle/Gears: 2.73 (for now)
Hey i just got a rebuilt trans installed in my car and the mechanic couldn't set the tv cable no matter what position it was in even trying to reset it by sliding it and pushing the carb throttle linkage to WOT it still seemed to shift late and it wouldnt go into 4th. I don't think the cable was ever set right with the old trans, some times it wouldnt downshift from 4th when i floored it. Im thinking maybe the cables bad but as someone else said it could be the wrong bracket its an edelbrook 600 carb. I have three questions are there different lengths of cables? If so which should i get and if not what bracket would i need for my carb, and how much will it hurt to drive back to the mechanics maybe 15ish miles i've already driven it home :/. Any help will be appreciated and i could use help asap
Old Oct 25, 2009 | 10:16 PM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
replace the cable then this website will answer all your questions to throttle valve cable set up http://www.tvmadeez.com/article/index.php
Old Oct 25, 2009 | 10:33 PM
xbox07's Avatar
Car: 86' Z28
Is there just one kind of cable like one size of cable for third gens or what?
Old Oct 25, 2009 | 10:37 PM
that question i cannot answer due to my laque of knowledge , i think that by just knowing what transmission you have enginsize and/or vehicle model you should be set " that is if your vehicle is stock .
Old Oct 25, 2009 | 10:40 PM
xbox07's Avatar
Car: 86' Z28
Thats the thing its an 86 and it was originally a fuel injected 305 but now its an edelbrock carbed 350 so i'm not sure what to look for.
Old Oct 25, 2009 | 10:49 PM
try summit , heres the link to a couple of adapters
http://www.summitracing.com/search/?...%20cable&dds=1
Old Oct 25, 2009 | 11:01 PM
xbox07's Avatar
Car: 86' Z28
Hum thanks, i hope i don't have to buy one :/ though, i think my cables bad so im getting a replacement anyway, are the carb and fuel injection ones different?
Old Oct 25, 2009 | 11:06 PM
probably , since most carb intake manifolds are high rise , they tend to take up more of the cable slack thus creating the shifting problem , IMO thats why they make adapters .
Old Oct 25, 2009 | 11:10 PM
xbox07's Avatar
Car: 86' Z28
Its got a spacer on it too wonder if that would affect it. Thanks for your help
Old Oct 25, 2009 | 11:12 PM
yes , the higher your car sits the more cable it will need , call and ask summit , they will help you get what you need .
Old Oct 25, 2009 | 11:14 PM
xbox07's Avatar
Car: 86' Z28
Thanks.
Old Oct 25, 2009 | 11:38 PM
xbox07's Avatar
Car: 86' Z28
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Detent-Cable-Motormite_3925269-P_657_R|GRPCABLAMS_603231172___
Would that be the right cable? Or should i get the B&M one from summit?
Old Oct 25, 2009 | 11:54 PM
Car: 1992 RS
Engine: Carbed 350
Yes - that looks like the right cable.
You'll also need this:
http://www.summitracing.com/parts/BMM-64511/
or similar from different brand. It's the geometry corrector that attaches to the varb linkage on the Edelbrock to ensure the geometry of the cable is correct.
And you'll need a good cable bracket - I used this one cause it was very nice and strong - didn't flex like the Spectre brand junk:
http://www.summitracing.com/parts/EDL-8030/
Old Oct 25, 2009 | 11:56 PM
Car: 1992 RS
Engine: Carbed 350
Here is Summit brand geometry corrector:
http://www.summitracing.com/parts/SUM-700203/
Old Oct 25, 2009 | 11:57 PM
xbox07's Avatar
Car: 86' Z28
Glad to see another night owl lol. I was just wondering about the cable because the B&M one from summit it like 30 somethin opposed to one i could get local for like 18. Why do i need the bracket?
Old Oct 26, 2009 | 12:03 AM
Car: 1992 RS
Engine: Carbed 350
You need a good bracket that will hold the throttle cable and the TV cable in place without flexing, and with proper alignment and spacing from the carb linkage.
You need the geometry corrector because even with the cable end the right distance from the linkage, the linkage alone doesn't allow the correct geometry of the cable in relation to the bracket (ie the cable will be too high or too low in relation to the bracket, thus the forces on it change when under pulling pressure from the throttle movement). If that makes sense. Forces are changed anytime up/down position is changed, not just cable length, and with the 700R4 this is not just a simple "kickdown" cable system, but it's much more precise "Throttle Valve" positioning system - thus the name TV cable rather than simply kickdown cable. Everything has to be just so with these TV cables or else the tranny can fry itself quick - it's all about pressure changes in TV as opposed to simple mechanical changes in kickdown.
Old Oct 26, 2009 | 12:07 AM
xbox07's Avatar
Car: 86' Z28
Looks like i have some things to order thanks. How much do you think it will hurt my new trans to drive it back to the mechanic 15ish miles away?. I feel bad for thread jacking but i wasn't getting any help in my thread.
Old Feb 18, 2011 | 10:36 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Where can I get that little connector? I don't want to have to replace the cable just because of a 10 cent piece of plastic...!
Old May 18, 2011 | 11:37 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
http://www.bulkpart.com/Merchant2/me...roduct_Count=0
That's a tv cable repair kit, it consists of the black clip that has a cut in it; which allows you to slide the cable wire into the clip and let the end of the wire sit in the clip.
I currently have one on my car, had it on since last winter. Works fine
Old Apr 9, 2012 | 11:49 AM
Jamdev's Avatar
Thank you so much for this link. I was searchng the internet for two days looking for something like this so I did not have to replace the cable. Was just about to order the cable and did one last search and found this thread!!!
Old Apr 9, 2012 | 03:19 PM
OrangeBird's Avatar
Car: 1989 Firebird
Yea , Me too , , , I'll add a Thank You as well . The clip on mine isn't completely broken yet , but it's close . I was not looking forward to replacing the cable , and now I wont have to .
Under $15 dollars shipped for a solution to that problem is great .
Old Apr 9, 2012 | 08:02 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
When I first drove my 86 IROC, the tv cable was not connected for some reason. It shifted hard, and late. My tranny guy said the pressure is up too high when the tv is not connected. Better than not enough pressure. I was concerned because I drove it a couple of days before I realized what was up. The fluid was nice and pink, and no burn smell.
Old Dec 22, 2014 | 04:47 PM
kuddybing's Avatar
Car: 85 Trans Am
Engine: carbed 350 four bolt
Transmission: 700R4 with shift kit
Axle/Gears: 373's
I know it a old thread but similar problems.... I know about the correctors but has anyone used the jegs brand corrector???? I ask cuz they look the same but the jegs is free shipping so its under $20 and with shipping the summit brand is $26 amd I only put a extra $20 on my card... any help out there for me thanks
Old Dec 22, 2014 | 04:49 PM
kuddybing's Avatar
Car: 85 Trans Am
Axle/Gears: 373's
O for reference running a 350 carbed with performer intake and 1" spacer with a 650 edlebrock carb
Frozer!!!
Jan 19, 2024 04:55 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
TheExaminer
Sep 6, 2015 11:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
