Failed emissions, nox is crazy high
Old Oct 25, 2009 | 05:42 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I took my car to get it inspected today, and failed smog miserably. High speed nox was 6811/1014, low speed was 7832/1110. My cat, O2 sensor, and EGR are barely a year old, no check engine light. However, the car did have some 4 month old gas in it, as it's been sitting a while. I put fresh gas in with the old gas, but could that be part of it? I'm gonna go do some datalogging in a bit, and see if anything looks odd. Any suggestions?
Old Oct 25, 2009 | 06:15 PM
Jeffs82TA's Avatar
Re: Failed emissions, nox is crazy high
that high means egr not working or passages plugged.
Old Oct 25, 2009 | 11:52 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
WOW! i have never seen NOx that high before.
around 3500 is the highest i've seen, and that was with the timing set too high, no EGR, no cat, and running lean because of a bad fuel pump.
bad gas can cause excessive emissions, so run all the old gas out of it with some super then make sure the timing is right and the EGR is working.
also check it for vacuum leaks, fuel pressure and overheating.
what were the other numbers?
Old Oct 26, 2009 | 08:19 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Here's the full printout. The HC was a little high, but that's probably due to my ford 19# injectors. I can fix that with a tune. Also, the gas cap failed, but that's easily replaceable.
Old Nov 3, 2009 | 07:31 PM
SMKNTRS's Avatar
You fix your problem? I am like double the limit and was wondering what worked for you.
Old Nov 3, 2009 | 07:46 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
prolly for a start-tee in a vac gauge to the egr valve line that you can run to the windshield and watch as you drive around to verify if you are getting any vacuum (pwm) to the egr valve. i agree-wow for the nox number. if vacuum is being applied-check your egr valve at idle with manual vacuum-it should make the motor stumble. check timing. retard as required. you may need a cat.
Old Nov 4, 2009 | 06:44 AM
SMKNTRS's Avatar
My problems seem to have started after I put a TPI fuel pump in my TBI 305. MY EGR is also stock with 120k on it. I might try to check the passage ways and run some high octance
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
89fast5oh
Sep 8, 2015 09:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
